15 years agoVHDL - FSM Design
Hello, I've posted this on comp.lang.vhdl, but it seems to be overridden with spam these days, so I don't think anyone will see it. I'm learning about FSMs and I'm having a hard time getting my ...
15 years agohello,
Thanks I did notice those mistakes and changed them, but my code still runs weird. I'm trying to figure out the problem now. I'm trying to learn how to use signal tap. Maybe that can tell me something about what's going on.LIBRARY ieee;
USE ieee.std_logic_1164.all;
USE ieee.numeric_std.all;
entity part1take2 is
port(
CLOCK_50 : in std_logic;
SW : in unsigned(1 downto 0);
LEDR : out unsigned(16 downto 0)
end part1take2;
architecture behavioral of part1take2 is
type statet is ( A, B, C, D, E, F, G, H, I );
constant FMil: integer := 50000000;
signal count : unsigned(25 downto 0);
signal CLK : std_logic;
signal cstate, nstate : statet;
signal led : unsigned(8 downto 0);
signal cled : unsigned(7 downto 0);
begin
LEDR(8 downto 0) <= led;
LEDR(16 downto 9) <= cled;
process(SW, cstate)
begin
if(SW(0) = '1') then
nstate <= A;
else
case cstate is
when A =>
led <= to_unsigned(000000001, 9);
if(SW(1) = '1') then
nstate <= F;
else
nstate <= B;
end if;
when B =>
led <= to_unsigned(000000010, 9);
nstate <= F;
else
nstate <= C;
end if;
when C =>
led <= to_unsigned(000000100, 9);
nstate <= F;
else
nstate <= D;
end if;
when D =>
led <= to_unsigned(000001000, 9);
nstate <= F;
else
nstate <= E;
end if;
when E =>
led <= to_unsigned(000010000, 9);
nstate <= F;
else
nstate <= E;
end if;
when F =>
led <= to_unsigned(000100000, 9);
nstate <= G;
else
nstate <= B;
end if;
when G =>
led <= to_unsigned(001000000, 9);
nstate <= H;
else
nstate <= B;
end if;
when H =>
led <= to_unsigned(010000000, 9);
nstate <= I;
else
nstate <= B;
end if;
when I =>
led <= to_unsigned(100000000, 9);
nstate <= I;
else
nstate <= B;
end if;
end case;
end if;
end process;
process(CLOCK_50) begin
if rising_edge(CLOCK_50) then
count <= count + 1;
cled <= cled + 1;
if(count = FMil) then
CLK <= (not CLK);
if(CLK = '1') then
cstate <= nstate;
end if;
end if;
end if;
end process;
end behavioral;
