17 years ago
Verilog Package File
Hi All,
I have some lines of code in my project like,
Caseaddr[7:0]
8'b 00000000 : reg <= '1';
8'b 00000001 : reg <= '0';
8'b11111111 : reg <= '1'
Here i would like to replace address with some names like ,
Caseaddr[7:0]
Reg1 : reg <= '1';
Reg2 : reg <= '0';
Regn : reg <= '1'
I have made a file REG_PKG.v and defined like,
'define 8'b 00000000 Reg1
But still compiler is throwing error saying that, Reg1, reg2 etc is not declared.
Here, i have compiled the Package file and added line `include in my original code.
Please help me, how to make a constants file in verilog similar to vhdl.
regards,
freak
    I would avoid using macros for this purpose. Macros (`define statements) are global to the entire project. I would use parameters instead. Specifically if you are using the Verilog 2001 or newer standard, I would make your REG_PKG.v file look like this:
    localparam Reg1 = 8'b00000000;
    localparam Reg2 = 8'b00000001;
    localparam Reg3 = 8'b00000010;
    Then inside your module that actually implements the case statement use the "`include" statment like this:
    `include "REG_PKG.v"
    case (addr)
         Reg1 : reg <= '1';
         Reg2 : reg <= '0';
    endcase
    Macros should be used with discretion.
    Jake
    One of your problems is that your defines are backwards. Change your defines to be like:
    'define Reg1 8'b00000000
    Then use it like mguimod suggested
    Case addr[7:0]
    `Reg1 : reg <= 1;
    `Reg2 : reg <= 0;
    Change:
    Case addr[7:0]
    Reg1 : reg <= '1';
    Reg2 : reg <= '0';
    Regn : reg <= '1'
    to
    Case addr[7:0]
    `Reg1 : reg <= 1;
    `Reg2 : reg <= 0;
    `Regn : reg <= 1;
