9 years agoVerify failed between address <> and <> Leaving target processor paused
Folks, I have the following simple SRAM circuit built using Qsys.
http://www.alteraforum.com/forum/attachment.php?attachmentid=13281&stc=1 I then instantiated the circuit on a top level module and programmed the board.entity SRAM is port(
CLK: in STD_LOGIC;
led: out STD_LOGIC;
--to/from SRAM
fsm_dq: inout std_logic_vector(15 downto 0);
fsm_addr: out std_logic_vector(19 downto 0);
sram_lb_n: out STD_LOGIC;
sram_ub_n: out STD_LOGIC;
sram_ce_n: out STD_LOGIC;
sram_oe_n: out STD_LOGIC;
sram_we_n: out STD_LOGIC
end SRAM;
Architecture Arch of SRAM is
component SRAM is
port (
clk_clk : in std_logic := '0'; -- clk.clk
reset_reset_n : in std_logic := '0'; -- reset.reset_n
sram_DQ : inout std_logic_vector(15 downto 0) := (others => '0'); -- sram_0_external_interface.DQ
sram_ADDR : out std_logic_vector(19 downto 0); -- .ADDR
sram_LB_N : out std_logic; -- .LB_N
sram_UB_N : out std_logic; -- .UB_N
sram_CE_N : out std_logic; -- .CE_N
sram_OE_N : out std_logic; -- .OE_N
sram_WE_N : out std_logic -- .WE_N
end component;
begin
SRAM_MAP: SRAM port map(
clk_clk=>CLK,
reset_reset_n=>'1',
sram_DQ=>fsm_dq,
sram_ADDR=>fsm_addr,
sram_LB_N=>sram_lb_n,
sram_UB_N=>sram_ub_n,
sram_CE_N=>sram_ce_n,
sram_OE_N=>sram_oe_n,
sram_WE_N=>sram_we_n
); When I programmed Nios for a simple Read/Write memory test operations, I keep getting verify failed between address 0x204200 and 0x20FFFF(which is the memory address space of the SRAM) error. I set the on-chip memory size to the maximum possible. I don't know what is wrong. Any idea? Cheers,3 Replies
There must be something wrong then, because with those settings the Nios programmer shouldn't try to write to the addresses 0x204200 - 0x20FFFF. Are you sure you are using the correct bsp and that it has been recompiled?
My onchip memory is the main RAM. I am using the Altera Monitor Program to program NIOS and here is the screen shot.
https://www.alteraforum.com/forum/attachment.php?attachmentid=13290 https://www.alteraforum.com/forum/attachment.php?attachmentid=13291 - Altera_Forum
You should change your bsd to use the onchip memory as the main RAM (for .text, .data, .bss and .head). Then you can generate a memory test application that will test the SRAM from there.
You can also add some Signaltap probes to the SRAM signals to check what the CPU is doing.
