9 years agoVerify failed between address <> and <> Leaving target processor paused
Folks, I have the following simple SRAM circuit built using Qsys. http://www.alteraforum.com/forum/attachment.php?attachmentid=13281&stc=1 I then instantiated the circuit on a top level mod...
9 years agoYou should change your bsd to use the onchip memory as the main RAM (for .text, .data, .bss and .head). Then you can generate a memory test application that will test the SRAM from there.
You can also add some Signaltap probes to the SRAM signals to check what the CPU is doing.
