9 years agoVerify failed between address <> and <> Leaving target processor paused
Folks, I have the following simple SRAM circuit built using Qsys. http://www.alteraforum.com/forum/attachment.php?attachmentid=13281&stc=1 I then instantiated the circuit on a top level mod...
9 years agoThere must be something wrong then, because with those settings the Nios programmer shouldn't try to write to the addresses 0x204200 - 0x20FFFF. Are you sure you are using the correct bsp and that it has been recompiled?
