17 years agoUsing Verilog Testbenches
Hello everybody,
I am trying to simulate my desing using a verilog testbench, excerpts as follows at the end of my message. Although I have checked that the testbench is included; logfiles show me that it has been included the post simulaiton results will not allow me to add any nodes to my resulting waveforms. Any ideas what I need to do ? Thanks a bunch in advance for your answers - Eric Hueckel`timescale 1ns/1ns
module test_pwm_fail_detect;
reg clk_i;
reg pwm0_i;
reg pwm1_i;
reg pwm2_i;
reg pwm3_i;
reg global_enable_i;
wire pwm_fail_o;
// instantiate the pwm failure detector
pwm_fail_detect m1 (clk_i,
pwm0_i,
pwm1_i,
pwm2_i,
pwm3_i,
global_enable_i,
pwm_fail_o);
// $monitor($time, ,"clk_i=%b ,pwm0_i=%b,",
// clk_i,pwm0_i );
// initial# 1200 $stop;
initial
begin
clk_i = 1'b0; //set clock and reset low initially
global_enable_i = 1'b0;
pwm0_i = 1'b0;
pwm1_i = 1'b0;
pwm2_i = 1'b0;
pwm3_i = 1'b0;
end
always# 38 clk_i = ~clk_i; //toggle clk_i every 38 ns = 13.157 mhz
initial
begin# 5 global_enable_i = 1'b1;
$stop; $finish;
end
endmodule
this is correct, you cannot use HDL test benches in Quartus. there is a free ModelSim-Altera Starter Edition that you should use instead. as mentioned it is a single language version.
--- Quote Start --- Hello GPK - Thanks a bunch for your quick reply, I apprecaite it. The Testbnech I showed was only to show how much testbench was written, correct, only running 5 ns. I wasn't detailed enough in my question which shold have stated, can I simulate a design using a verilog testbench in Quartus II ? I believe the answer is no, I can see the dialog under settings => simulator settings => simulation input only calls for .vwf, .cvwf, .vec, .tbl, .scf, .vcd and not .v files. It looks liek Quartus can't interpret a Verilog testbench, is that right ? Thanks again from southern Germany !! Eric --- Quote End --- Hi Eric, as far as a know you can not use a verilog testbench with the Quartus build in simulator. I use the simulator only for small simulations with only a few input vectors. For larger simulations I recommand to use simulator like Modelsim etc. A modelsim version is available on the Altera website, but I think it supports not multi languages designs. Kind regards GPK - Altera_Forum
Hello GPK -
Thanks a bunch for your quick reply, I apprecaite it. The Testbnech I showed was only to show how much testbench was written, correct, only running 5 ns. I wasn't detailed enough in my question which shold have stated, can I simulate a design using a verilog testbench in Quartus II ? I believe the answer is no, I can see the dialog under settings => simulator settings => simulation input only calls for .vwf, .cvwf, .vec, .tbl, .scf, .vcd and not .v files. It looks liek Quartus can't interpret a Verilog testbench, is that right ? Thanks again from southern Germany !! Eric - Altera_Forum
--- Quote Start --- Hello everybody, I am trying to simulate my desing using a verilog testbench, excerpts as follows at the end of my message. Although I have checked that the testbench is included; logfiles show me that it has been included the post simulaiton results will not allow me to add any nodes to my resulting waveforms. Any ideas what I need to do ? Thanks a bunch in advance for your answers - Eric Hueckel`timescale 1ns/1ns
reg clk_i;
reg pwm0_i;
reg pwm1_i;
reg pwm2_i;
reg pwm3_i;
wire pwm_fail_o;
pwm0_i,
pwm1_i,
pwm2_i,
pwm3_i,
global_enable_i,
pwm_fail_o);
// clk_i,pwm0_i );
initial
begin
pwm0_i = 1'b0;
pwm1_i = 1'b0;
pwm2_i = 1'b0;
pwm3_i = 1'b0;
end
initial
begin
$stop; $finish;
end
endmodule
--- Quote End --- Hi Eric, how long is your testbench running ? With your posted testbench I would assume that the simulation will stop after 5ns ??? Which simualtion tool do you use ? Kind regards GPK
