17 years agoUsing Verilog Testbenches
Hello everybody, I am trying to simulate my desing using a verilog testbench, excerpts as follows at the end of my message. Although I have checked that the testbench is included; logfiles s...
17 years ago --- Quote Start --- Hello GPK - Thanks a bunch for your quick reply, I apprecaite it. The Testbnech I showed was only to show how much testbench was written, correct, only running 5 ns. I wasn't detailed enough in my question which shold have stated, can I simulate a design using a verilog testbench in Quartus II ? I believe the answer is no, I can see the dialog under settings => simulator settings => simulation input only calls for .vwf, .cvwf, .vec, .tbl, .scf, .vcd and not .v files. It looks liek Quartus can't interpret a Verilog testbench, is that right ? Thanks again from southern Germany !! Eric --- Quote End --- Hi Eric, as far as a know you can not use a verilog testbench with the Quartus build in simulator. I use the simulator only for small simulations with only a few input vectors. For larger simulations I recommand to use simulator like Modelsim etc. A modelsim version is available on the Altera website, but I think it supports not multi languages designs. Kind regards GPK
