16 years agousing memory Bits
Hi i wrote a vhdl design in which i wanted to buffer data like this:
WHEN 0 => ausgangimag0 <=ausgangimag0 + resultim;ausgang2 <= ausgangimag0; WHEN 1 => ausgangimag1 <=ausgangimag1 + resultim;ausgang2 <= ausgangimag1; WHEN 2 => ausgangimag2 <=ausgangimag2 + resultim;ausgang2 <= ausgangimag2; WHEN 3 => ausgangimag3 <=ausgangimag3 + resultim;ausgang2 <= ausgangimag3; WHEN 4 => ausgangimag4 <=ausgangimag4 + resultim;ausgang2 <= ausgangimag4; .... and so on only much more. when i compile the design i get the error: "Error: Design contains 77634 blocks of type combinational node. However, device contains only 33216." But the memory Bits of the FPGA are empty (0 / 483840). How can i use them to buffer the data?3 Replies
Read this document (http://www.altera.com/literature/hb/qts/qts_qii51007.pdf) to learn how to properly infer memories in VHDL code.
do you want to store it in regsiters or in RAM-cells ?
obviously you dindt make any storage elements, so all of your assignments lead to a pure combinational logic - Altera_Forum
Generally you have to observe the rules for RAM inference. Using the same signal for RAM read and write as in ausgangimag1 <=ausgangimag1 + resultim doesn't work I think. You should show the complete process layout for clarification.
You better start from the Quartus VHDL templates.
