17 years ago
Use defines in Verilog
I have some problems using defines in Verilog.
I want to define memory depth & width, and then to use these
defines for the memory name.
For example - memory name should be ram512x32
`define depth 512
`define width 32
`define memory_name ram `depth x `width
Is there a way to do it in Verilog ?
    You need System Verilog, I don't think you can do that on Verilog-2001. I don't know if this System Verilog feature is supported by Quartus, but you could try.
    The problem in this case is assembling a continuous text string. Preprocessor define directive requires white spaces separating the arguments, that isn't suitable in this case. There may be an option to achieve your intention through "$" system functions, but I'm not used to it.
    You can use parameter.
    For example:
    parameter depth = 512;
    etc.
