...Before I didn't see the "System" log. When I tried, Programmer gave my this error: "Error: JTAG ID code specified in JEDEC STAPL Format File does not match any valid JTAG ID codes for device". Then I found some information about this problem on Altera Forum. Some guy said to connect a pull-down resistor to TCK pin.
But it did not fix the error.
I measure the voltage on the pins:
TCK = around 0 volts = constant
TDO = 4 volts = constant
TMS = around 0 volts = constant
and TDI = some signal with amplitude 1v
Also, I opened my USB Blaster and... there is no any CPLD inside. It based on uC 'Silabs' with IC 74LVC125. Maybe because it is the chip USB Blaster. I bought that in Ebay...
Thank you very much,
Yaroslav.
