12 years agoUSB Blaster problem
Hello, I have a chip USB Blaster Rev C. When I program CPLD EPM7064SLC44-10 with Quartus II sp2 12.0 programmer, the process bar goes to 100% and then it shows "Failed". How can I fix this erro...
12 years agoHi Yaroslav,
--- Quote Start --- The solution was to connect USB-Blaster directly to CPLD (through 74HC244) --- Quote End --- What was wrong with the 74LVC125 on the SiLabs USB-Blaster? --- Quote Start --- connect VCCtarget and +5Vcpld together --- Quote End --- Your board should have already done that, i.e., the VCC_TARGET pin on the USB-Blaster is supposed to power the buffer inside the USB-Blaster. That is how the USB-Blaster ensures the logic levels transmitted to the board are compatible with the device. If your board did not connect VCC_TARGET, then that would explain the problem. Cheers, Dave
