12 years agoUSB Blaster problem
Hello, I have a chip USB Blaster Rev C. When I program CPLD EPM7064SLC44-10 with Quartus II sp2 12.0 programmer, the process bar goes to 100% and then it shows "Failed". How can I fix this erro...
12 years agoHi Yaroslav,
I would also try a different USB Cable than the one that is provided with the Altera USB-Blaster. Depending where you Purchased your USB-BLASTER, sometimes the Stock USB cables are very cheap and are prone to Shorts or an OPEN connection. Can you post a Picture of how you're interfacing the chip? It would help to see your interface setup. Cheers! -Gerry
