9 years agoUnconstrained Path in PFL IP core
Hallo
I am making a PFL IP core for a MAX V device. and i wrote a SDC file based on the application note 478,the PFL IP core user guide. which is available on the following link. I used table 7 from the link to set the clock, set false path and set output delay for the paths. https://www.altera.com/documentation/sss1411439280066.html#sss1458191622012 But i can still see that some paths are still not constrained, and some paths are partially constrained. Like the flash address [0-20] & flash data [0-15] are suggested to set as false path in the user guide, but after setting them to false path i can still see them in the unconstrained paths list. What could be the reason for this? Am i wrong with the commands i write to set them as a false path? I am attaching the SDC file that i generated from Timing analyzer tool. can you please have a look and suggest me what changes are necessary.2 Replies
i am attaching my whole project file here. maybe this helps with the settings and everything
Could you post the output of the Timing analyzer, complete file. It will help in finding out which path is unconstrained.
