Unable to Infer M9K in Quartus
Hi all,
I borrowed some code from a Xilinx project, where RAM was inferred successfully. I would like to do the same in my Quartus 18.1 project with my MAX10 FPGA DevKit. Here's both methods of inferring I have attempted:
reg [(DWIDTH-1):0] mem [(1<<AWIDTH)-1:0] /* synthesis ramstyle = M9K */;
(* ramstyle = "M9K" *) reg [(DWIDTH-1):0] mem [(1<<AWIDTH)-1:0];
Neither of which throw any errors or warnings (searched Quartus console).
I have also checked the resource utilization report, and see Logic Cells (~10,000) / Dedicated Logic Registers (~8000) being used rather than M9Ks (0).
Thanks in advance!
Your code for the memory block itself is way too complicated for Quartus to infer it from block rams.
You need to look at the verilog templates that Quartus supplies for inferred memory.
Here is what I use and it infers as block ram (M9K, M4K depending) just fine.
Note addr, mdi, mwr are wire type; mdo are reg type.
reg [0:11] memory [0:MEMSIZE-1] /* synthesis ramstyle = "no_rw_check" */;
always @(posedge clk)
begin
if (mwr) memory[addr] <= #TPD mdi;
mdo <= #TPD memory[addr];
end
- sstrell
Where is the code for how the RAM is to operate? If you don't code the RAM properly, it's not going to get inferred into a RAM block.
- GDagi1
always@(posedge clk) begin
if(rst) begin
// set things to 0
end
else begin
if((|wea_r) && wr_ena_r) begin
for (i = 0; i < (DWIDTH/8); i=i+1) begin
if (wea_r[i]) begin
for (j = 0; j < 8; j = j + 1) begin
mem[wr_addr_r][(8*i)+j] <= data_in_r[(8*i)+j] && wea_r[i];
end
end
end
end
if (rd_ena)
data_out_r <= mem[rd_addr_r];
else
data_out_r <= 0;
end
end- ak6dn
begin
end
