Unable to Infer M9K in Quartus
- 5 years ago
Your code for the memory block itself is way too complicated for Quartus to infer it from block rams.
You need to look at the verilog templates that Quartus supplies for inferred memory.
Here is what I use and it infers as block ram (M9K, M4K depending) just fine.
Note addr, mdi, mwr are wire type; mdo are reg type.
reg [0:11] memory [0:MEMSIZE-1] /* synthesis ramstyle = "no_rw_check" */;
always @(posedge clk)
begin
if (mwr) memory[addr] <= #TPD mdi;
mdo <= #TPD memory[addr];
end
always@(posedge clk) begin
if(rst) begin
// set things to 0
end
else begin
if((|wea_r) && wr_ena_r) begin
for (i = 0; i < (DWIDTH/8); i=i+1) begin
if (wea_r[i]) begin
for (j = 0; j < 8; j = j + 1) begin
mem[wr_addr_r][(8*i)+j] <= data_in_r[(8*i)+j] && wea_r[i];
end
end
end
end
if (rd_ena)
data_out_r <= mem[rd_addr_r];
else
data_out_r <= 0;
end
end
begin
end
- GDagi15 years ago
Yep, this seemed to be it. I switched to the Quartus template and it worked.
- RichardT_altera5 years ago
Shyan Yew
