UART Transmitter Sends Bytes Out of Order
I have the following Verilog code which sends 8 bytes to the serial port successively after a button is pressed. The problem is, the bytes are sent out of order as to what I would expect. For example, if I send out the bytes 0xde, 0xad, 0xbe, 0xef, 0xde, 0xad, 0xbe, 0xef - the PC gets 0xef, 0xad, 0xef, 0xad and sometimes does not receive the rest and will hang-up. I've looked at this code many times, and can't seem to figure out why this might be. Am I using the part-select incorrectly? I don't think so, but I don't know what else could be the issue. I've attached a second version of this code that does work(meaning all the bytes are received and in the correct order), but it takes an extra clock cycle because it updates the data in the shift register after each transmission. If you can see any reason why the first version posted does not work, but the second does - please let me know! Any suggestions are greatly appreciated. Kristin
module transmission_test_2(sysclk, rxd, txd, LED, button);
input sysclk, rxd, button;
output txd;
output reg LED;
wire receiving_complete, isReceiving, isTransmitting, isError;
reg begin_transmit;
reg tbyte;
wire rbyte;
reg state;
reg plain_text;
integer byteN;
parameter IDLE = 0, BEGIN_TRANSMISSION = 1, UPDATE_DATA = 2, SEND_BYTES = 3;
uart uart1(
.clk(sysclk),
.rx(rxd),
.tx(txd),
.transmit(begin_transmit),
.tx_byte(tbyte),
.received(receiving_complete),
.rx_byte(rbyte),
.is_receiving(isReceiving),
.is_transmitting(isTransmitting),
.recv_error(isError)
always @(posedge sysclk)
begin
begin_transmit = 1'b0;
case(state)
IDLE: begin
if(button==1'b0) begin
LED = 1'b1;
plain_text = 64'hDEADBEEFDEADBEEF;
state = BEGIN_TRANSMISSION;
end else begin
LED <= 1'b0;
end
end
BEGIN_TRANSMISSION: begin
tbyte = plain_text;
begin_transmit = 1'b1;
byteN = 1;
state = SEND_BYTES;
end
SEND_BYTES: begin
if(!isTransmitting) begin
tbyte = plain_text;
byteN = byteN + 1;
if(byteN == 8) begin
state = IDLE;
end
end
end
endcase
end
endmodule
module transmission_test(sysclk, rxd, txd, LED, button);
output txd;
output reg LED;
reg begin_transmit;
reg tbyte;
wire rbyte;
reg state;
reg plain_text;
integer bytes_remaining;
parameter IDLE = 0, BEGIN_TRANSMISSION = 1, UPDATE_DATA = 2, SEND_BYTES = 3, DONE = 4;
uart uart1(
.clk(sysclk),
.rx(rxd),
.tx(txd),
.tx_byte(tbyte),
.rx_byte(rbyte),
begin
case(state)
IDLE: begin
LED = 1'b1;
end else begin
LED <= 1'b0;
end
end
tbyte = plain_text;
bytes_remaining = 7;
state = UPDATE_DATA;
end
UPDATE_DATA: begin
plain_text = plain_text >> 8;
state = SEND_BYTES;
end
SEND_BYTES: begin
tbyte = plain_text;
bytes_remaining = bytes_remaining - 1;
if(bytes_remaining == 0) begin
state = IDLE;
end else begin
end
end
end
endcase
end
endmodule
FWIW HyperTerm is a bad choice of program, it is designed(?) to talk to modems and can get confused if the modem signal lines are incorrect.
Its UI is also painful. putty (free download) works a lot better on serial lines (as well as for ssh etc). - Altera_Forum
Here is a version of your code that I modified somewhat and it works quite well. I'm using HyperTerm at 9600 8-N-2 to display the xmitted chars. Note the order in which 'plain_text' is read. For valid printing chars to be displayed you cannot send 0xDEADBEEF but rather its ASCII equivalent. There are some additional little changes, for example, tbyte = plain_text[(byteN*8)-1 -: 8] and the state machine runs at 4-KHz. No changes to uart.v except for some cosmetics.
rgs - Altera_Forum
Quite cleary isTransmitting is active for 2 clocks.
It won't be seen inactive until the clock after the uart sees begin_transmit active. - Altera_Forum
As an alternative, I also tried removing the "catch-all" state for sending all 8 bytes and created a separate state for each byte that needed to be sent.
However, the result is still the same. I receive every other byte. What gives? Any ideas? Below is the code:module transmission_test_3(sysclk, rxd, txd, LED, button); input sysclk, rxd, button; output txd; output reg LED; wire receiving_complete, isReceiving, isTransmitting, isError, reset; reg begin_transmit; reg tbyte; wire rbyte; reg state = 4'b0; reg plain_text = 64'h0; uart uart1( .clk(sysclk), .rst(reset), .rx(rxd), .tx(txd), .transmit(begin_transmit), .tx_byte(tbyte), .received(receiving_complete), .rx_byte(rbyte), .is_receiving(isReceiving), .is_transmitting(isTransmitting), .recv_error(isError) ); always @(posedge sysclk) begin begin_transmit = 1'b0; case(state) 4'b0000: begin if(button==1'b0) begin LED = 1'b1; plain_text = 64'hDEADBEEFAAABACAD; state = 4'b0001; end else begin LED = 1'b0; end end 4'b0001: begin tbyte = plain_text; begin_transmit = 1'b1; state = 4'b0010; end 4'b0010: begin if(!isTransmitting) begin tbyte = plain_text; begin_transmit = 1'b1; state = 4'b0011; end end 4'b0011: begin if(!isTransmitting) begin tbyte = plain_text; begin_transmit = 1'b1; state = 4'b0100; end end 4'b0100: begin if(!isTransmitting) begin tbyte = plain_text; begin_transmit = 1'b1; state = 4'b0101; end end 4'b0101: begin if(!isTransmitting) begin tbyte = plain_text; begin_transmit = 1'b1; state = 4'b0110; end end 4'b0110: begin if(!isTransmitting) begin tbyte = plain_text; begin_transmit = 1'b1; state = 4'b0111; end end 4'b0111: begin if(!isTransmitting) begin tbyte = plain_text; begin_transmit = 1'b1; state = 4'b1000; end end 4'b1000: begin if(!isTransmitting) begin tbyte = plain_text; begin_transmit = 1'b1; state = 4'b0000; end end endcase end endmodule - Altera_Forum
@Cris72: No, it's not a typo - it's called part-select - added to the language in Verilog 2001. Your version would be simpler, except that it isn't allowed. One of the indices in the part-select must be a constant/literal and the other may be a variable - but they can't both contain variables.
@kosh271: Here is the code for uart1:
I've also attached an image of the simulation for all relevant signals: https://docs.google.com/open?id=0b4wyejzmihtnadbib1njtzrymta Looking at the output, it's obvious that byteN is increasing by two instead of one - and that's why I'm getting every other byte. However, I still don't see why this is happening. Is it because I sample the value of byteN and update its value in the same clock cycle? I didn't think this would be a problem - since I'm using blocking assignments and also because I'm following a similar convention in the version of the code that is working. Any insights? :)module uart( input clk, // The master clock for this module input rst, // Synchronous reset. input rx, // Incoming serial line output tx, // Outgoing serial line input transmit, // Signal to transmit input tx_byte, // Byte to transmit output received, // Indicated that a byte has been received. output rx_byte, // Byte received output is_receiving, // Low when receive line is idle. output is_transmitting, // Low when transmit line is idle. output recv_error // Indicates error in receiving packet. ); parameter CLOCK_DIVIDE = 1302; // clock rate (50Mhz) / (baud rate (9600) * 4) // States for the receiving state machine. // These are just constants, not parameters to override. parameter RX_IDLE = 0; parameter RX_CHECK_START = 1; parameter RX_READ_BITS = 2; parameter RX_CHECK_STOP = 3; parameter RX_DELAY_RESTART = 4; parameter RX_ERROR = 5; parameter RX_RECEIVED = 6; // States for the transmitting state machine. // Constants - do not override. parameter TX_IDLE = 0; parameter TX_SENDING = 1; parameter TX_DELAY_RESTART = 2; reg rx_clk_divider = CLOCK_DIVIDE; reg tx_clk_divider = CLOCK_DIVIDE; reg recv_state = RX_IDLE; reg rx_countdown; reg rx_bits_remaining; reg rx_data; reg tx_out = 1'b1; reg tx_state = TX_IDLE; reg tx_countdown; reg tx_bits_remaining; reg tx_data; assign received = recv_state == RX_RECEIVED; assign recv_error = recv_state == RX_ERROR; assign is_receiving = recv_state != RX_IDLE; assign rx_byte = rx_data; assign tx = tx_out; assign is_transmitting = tx_state != TX_IDLE; always @(posedge clk) begin if (rst) begin recv_state = RX_IDLE; tx_state = TX_IDLE; end // The clk_divider counter counts down from // the CLOCK_DIVIDE constant. Whenever it // reaches 0, 1/16 of the bit period has elapsed. // Countdown timers for the receiving and transmitting // state machines are decremented. rx_clk_divider = rx_clk_divider - 1; if (!rx_clk_divider) begin rx_clk_divider = CLOCK_DIVIDE; rx_countdown = rx_countdown - 1; end tx_clk_divider = tx_clk_divider - 1; if (!tx_clk_divider) begin tx_clk_divider = CLOCK_DIVIDE; tx_countdown = tx_countdown - 1; end // Receive state machine case (recv_state) RX_IDLE: begin // A low pulse on the receive line indicates the // start of data. if (!rx) begin // Wait half the period - should resume in the // middle of this first pulse. rx_clk_divider = CLOCK_DIVIDE; rx_countdown = 2; recv_state = RX_CHECK_START; end end RX_CHECK_START: begin if (!rx_countdown) begin // Check the pulse is still there if (!rx) begin // Pulse still there - good // Wait the bit period to resume half-way // through the first bit. rx_countdown = 4; rx_bits_remaining = 8; recv_state = RX_READ_BITS; end else begin // Pulse lasted less than half the period - // not a valid transmission. recv_state = RX_ERROR; end end end RX_READ_BITS: begin if (!rx_countdown) begin // Should be half-way through a bit pulse here. // Read this bit in, wait for the next if we // have more to get. rx_data = {rx, rx_data}; rx_countdown = 4; rx_bits_remaining = rx_bits_remaining - 1; recv_state = rx_bits_remaining ? RX_READ_BITS : RX_CHECK_STOP; end end RX_CHECK_STOP: begin if (!rx_countdown) begin // Should resume half-way through the stop bit // This should be high - if not, reject the // transmission and signal an error. recv_state = rx ? RX_RECEIVED : RX_ERROR; end end RX_DELAY_RESTART: begin // Waits a set number of cycles before accepting // another transmission. recv_state = rx_countdown ? RX_DELAY_RESTART : RX_IDLE; end RX_ERROR: begin // There was an error receiving. // Raises the recv_error flag for one clock // cycle while in this state and then waits // 2 bit periods before accepting another // transmission. rx_countdown = 8; recv_state = RX_DELAY_RESTART; end RX_RECEIVED: begin // Successfully received a byte. // Raises the received flag for one clock // cycle while in this state. recv_state = RX_IDLE; end endcase // Transmit state machine case (tx_state) TX_IDLE: begin if (transmit) begin // If the transmit flag is raised in the idle // state, start transmitting the current content // of the tx_byte input. tx_data = tx_byte; // Send the initial, low pulse of 1 bit period // to signal the start, followed by the data tx_clk_divider = CLOCK_DIVIDE; tx_countdown = 4; tx_out = 0; tx_bits_remaining = 8; tx_state = TX_SENDING; end end TX_SENDING: begin if (!tx_countdown) begin if (tx_bits_remaining) begin tx_bits_remaining = tx_bits_remaining - 1; tx_out = tx_data; tx_data = {1'b0, tx_data}; tx_countdown = 4; tx_state = TX_SENDING; end else begin // Set delay to send out 2 stop bits. tx_out = 1; tx_countdown = 8; tx_state = TX_DELAY_RESTART; end end end TX_DELAY_RESTART: begin // Wait until tx_countdown reaches the end before // we send another transmission. This covers the // "stop bit" delay. tx_state = tx_countdown ? TX_DELAY_RESTART : TX_IDLE; end endcase end endmodule - Altera_Forum
--- Quote Start --- In the first piece of code (the not working one) in SEND_BYTES state you wrote: tbyte = plain_text[byteN*8 +: 8]; What does that mean? I have never seen such a syntax. Is this a typo? I'd rather used: tbyte = plain_text[(byteN+1)*8: byteN*8]; --- Quote End --- Check section 4.2.1 of the 1364-2001 spec, Vector bit-select and part-select addressing fe, if you declare a reg as: reg [15:0] d, then d[0 +: 8] is equivalent to d[7:0] if you declare it as: reg [0:15] d, then d[0 +: 8] is equivalent to d[0:7] there is also a -: operator that works similarly As for the question in hand, you should get a simulator (there are free ones), and check your timing constraints - Altera_Forum
tbyte = plain_text[byteN*8 +: 8]; What does that mean? I have never seen such a syntax. Is this a typo? I'd rather used: tbyte = plain_text[(byteN+1)*8: byteN*8]; - Altera_Forum
I'd test without repeated byte values - might make it slightly more obvious what is going on.
There isn't quite enough here to go on, but I'll hazard a guess. The code for uart1 is critical.
If the isTransmitting signal is generated using a clocked process, (sorry for the terminology, I'm a VHDL guy) the isTransmitting signal will go high at least 1 clock after begin_transmit is set high. This will cause if(!isTransmitting) to be true. A Verilog simulator would probably show you exactly what is going on. If you are still stuck on this, post the uart code. It will help fill in the gaps.
