14 years agoUART Transmitter Sends Bytes Out of Order
Hello, I have the following Verilog code which sends 8 bytes to the serial port successively after a button is pressed. The problem is, the bytes are sent out of order as to what I would e...
14 years agoAs an alternative, I also tried removing the "catch-all" state for sending all 8 bytes and created a separate state for each byte that needed to be sent.
However, the result is still the same. I receive every other byte. What gives? Any ideas? Below is the code:
module transmission_test_3(sysclk, rxd, txd, LED, button);
input sysclk, rxd, button;
output txd;
output reg LED;
wire receiving_complete, isReceiving, isTransmitting, isError, reset;
reg begin_transmit;
reg tbyte;
wire rbyte;
reg state = 4'b0;
reg plain_text = 64'h0;
uart uart1(
.clk(sysclk),
.rst(reset),
.rx(rxd),
.tx(txd),
.transmit(begin_transmit),
.tx_byte(tbyte),
.received(receiving_complete),
.rx_byte(rbyte),
.is_receiving(isReceiving),
.is_transmitting(isTransmitting),
.recv_error(isError)
always @(posedge sysclk)
begin
begin_transmit = 1'b0;
case(state)
4'b0000: begin
if(button==1'b0) begin
LED = 1'b1;
plain_text = 64'hDEADBEEFAAABACAD;
state = 4'b0001;
end else begin
LED = 1'b0;
end
end
4'b0001: begin
tbyte = plain_text;
begin_transmit = 1'b1;
state = 4'b0010;
end
4'b0010: begin
if(!isTransmitting) begin
tbyte = plain_text;
state = 4'b0011;
end
end
4'b0011: begin
tbyte = plain_text;
state = 4'b0100;
end
end
4'b0100: begin
tbyte = plain_text;
state = 4'b0101;
end
end
4'b0101: begin
tbyte = plain_text;
state = 4'b0110;
end
end
4'b0110: begin
tbyte = plain_text;
state = 4'b0111;
end
end
4'b0111: begin
tbyte = plain_text;
state = 4'b1000;
end
end
4'b1000: begin
tbyte = plain_text;
state = 4'b0000;
end
end
endcase
end
endmodule
