16 years agoTip/suppornt on debugging a VHDL project on Altera
Hi
I have some experience on hdl coding, but none on FPGA debugging. (which does not necessarily mean the problem may not be in my HDL coding... ;) ) I´m facing a weird (imho) situation in which two signals are touched within an 'if' block. In simulation everything is doing fine, but when I got it programmed and running on FPGA, only one of them is touched. The piece of VHDL code is the following: flash_process(clk) begin if(rst='1') then ............ int_flash_en <= '0'; etcmiv_data_rdy_detected <= '0'; ............ elsif(rising_edge(clk)) then if (..........) then ............ elsif(......) then if(.....) then ..... else if((etcmiv_data_rdy = '1') and (int_flash_en = '0')) then etcmiv_data_rdy_detected <= '1'; end if; if((clk_spi_flash = '1') and (int_flash_en = '0') and (etcmiv_data_rdy_detected = '1'))then int_flash_en <= '1'; etcmiv_data_rdy_detected <= '0'; ........ ....... else ...... int_flash_en <= '0'; ....... The only places in code where these two signals (int_flash_en and etcmiv_data_rdy_detected) are touched are listed above. When running on FPGA, I got a positive pulse on etcmiv_data_rdy_detected, but int_flash_en remains untouched ('0'). I was supposing etcmiv_data_rdy_detected should only go down together with int_flash_en assertion. Is my assumption wrong? Can anybody help me with some light on that? I am using Quartus II 9.1 web edition and ModelSim Altera Starter Edition 6.5b. My FPGA is a CycloneIII EP3C25Q240C8N Thanks in advance Cristiano13 Replies
Hello Cristiano, It might be better if you post your complete code to see where the problem is. From the above code you have posted, I do not see why your "int_flash_en" is not enabled when "etcmiv_data_rdy_detected" goes low. Please check your code if you have any other assignment for int_flash_en outside the process. Most likely it might be the case. all the best.
Please post more code - the snippets you posted without indentation are rather confusing
On first glance - I worry whenever I see a signal called "clk" thats being checked in an if statement rather than being used as an actual clock. - Altera_Forum
Post the whole code, not just redacted sections. You most likely have a problem with your logic, but won't be able to tell unless everything is posted.
Kevin
