16 years agoTip/suppornt on debugging a VHDL project on Altera
Hi I have some experience on hdl coding, but none on FPGA debugging. (which does not necessarily mean the problem may not be in my HDL coding... ;) ) I´m facing a weird (imho) situation ...
16 years agoHello Cristiano, It might be better if you post your complete code to see where the problem is. From the above code you have posted, I do not see why your "int_flash_en" is not enabled when "etcmiv_data_rdy_detected" goes low. Please check your code if you have any other assignment for int_flash_en outside the process. Most likely it might be the case. all the best.
