15 years agoTiming constraints for output clock pin
I'm constraining a synchronous interface to a USB chip, and I've got all the timing constraints in for the data and control lines. Timequest is still listing the output clock itself as unconstrained. Do I need to constrain this? Ultimately as long as all the other constraints are met, I don't really care how much delay is present between the PLL clock output and the clock output pin. Should I set a false path to the output clock pin, or is there some other recommended thing to do?
Regards, David2 Replies
Thanks kaz!
as you have realised clk output does not need constraints by itself. to keep timequest happy set false path:
set_false_path -to [get_ports {clkout}] exception to that if you need to treat it as any nonclk output
