16 years agotime in generic clause of entity for synthesis
Dear All,
is it possible to use generic of type 'time' in an entity declaration which is used for synthesis? I'd like to use time specification as top-entity generic parameter, which is in the sub-entity recalculated to integer and hence it is fully synthesizable (recalculation using e.g. 100 ns / 25 ns leads to integer right?). This works great in simulation, however quartus refuses to instantiate block claiming that 's' does not exist: entity top_entity is generic ( DELAY_LINE_DEPTH : integer := 8; --! default FIFO used for BLR RESET_PULSE_LENGTH : integer := 50; --! length of automatically generated reset BCF_DEFAULT_THRESHOLD_VALUE : integer := 3700; --! default value of threshold loaded when register is reset MAX6627_AUTORUN : time := 2s); --! autorun of max circuit
