16 years agotime in generic clause of entity for synthesis
Dear All, is it possible to use generic of type 'time' in an entity declaration which is used for synthesis? I'd like to use time specification as top-entity generic parameter, which is in the sub...
16 years agoyup - your idea synthesises fine.
here is some code I just synthesised fine in Q9.1 SP1
library ieee;
use ieee.std_logic_1164.all;
use ieee.std_logic_misc.all;
use ieee.numeric_std.all;
entity test_build is
generic (XOSC : time := 25 ns;
DELAY_TO_OUTPUT : time := 2 us
port (
--Clock and reset
clk : in std_logic;
a : in std_logic;
b : out std_logic
end entity;
architecture rtl of test_build is
constant NUMTICKS : integer := DELAY_TO_OUTPUT / XOSC;
signal dly : std_logic_vector(NUMTICKS-1 downto 0);
begin
process(clk)
begin
if rising_edge(clk) then
dly <= dly(dly'high-1 downto 0) & a;
b <= dly(dly'high);
end if;
end process;
end architecture rtl;
