16 years agotime in generic clause of entity for synthesis
Dear All, is it possible to use generic of type 'time' in an entity declaration which is used for synthesis? I'd like to use time specification as top-entity generic parameter, which is in the sub...
16 years agoHi Tricky,
frankly, I do not understand why following construct should make any problems to synthesizer (however meaningless the example is): entity mystuff is generic (XOSC : time := 25 ns; DELAY_TO_OUTPUT : time := 2 us); port (ClkxC : in std_logic; ResetxRNA : in std_logic; QxS : out std_logic); end entity mystuff; architecture v1 of mystuff is constant NUMTICKS : integer := DELAY_TO_OUTPUT / XOSC; component clock_divider is generic (DIVIDER : integer); port (ClkxC : in std_logic; pResetxRNA : in std_logic; ClkxE : out std_logic); end component clock_divider; begin -- architecture v1 DIDI : clock_divider generic map (DIVIDER => NUMTICKS) port map (ClkxC => ClkxC, pResetxRNA => ResetxRNA, ClkxE => QxS); end architecture v1; IMHO this is fully synthesizable as division of two time units is unitless hence could be casted to integer and it is really clear what the synthesizer should do with that. Am I right? d.
