xingyunzhidi
1 year agoThe issue encountered when programming the POF file into MAX10
After powering on my FPGA development board, the power status LED did not light up, so I checked it and found that the issue was with the MAX10 chip. I then planned to reprogram the MAX10 using the m...
xingyunzhidi
1 year ago- Yes, I mean D6.
- I set SW8 to OFF/ON/ON/OFF.
- D14 is lit.
Where could the issue be?
lixy
Contributor
1 year agoHi Xingyunzhidi,
1- Make sure again you are using the micro USB cable to plug into J8 instead of using USB blaster.
2- Could you measure the voltage at the pin1 and pin_3 of the SW8? Just to confirm whether there could be anything wrong with this Switch.
Pin_1 should be ~3.3V.
Pin 3 should be ~0V (the USB_MAX_JTAGSEL signal should be 1'b0 to enable MAX 10 JTAG).
It could be a bit difficult to confirm where the pin_1 is, but you can understand from the schematic that the pin_8 and pin_7 are ~0V.
Xiaoyan
