xingyunzhidi
1 year agoThe issue encountered when programming the POF file into MAX10
After powering on my FPGA development board, the power status LED did not light up, so I checked it and found that the issue was with the MAX10 chip. I then planned to reprogram the MAX10 using the m...
lixy
Contributor
1 year agoHi Fabian,
1- Do you mean that you have seen the CRC error but the Factory image fallback didn't happen?
2- For question 2, do you mean that, in Application Configuration, you didn't assert the RU_nRSTIMER, but the Factory image fallback didn't happen?
Xiaoyan
