The Fitter failed to find a legal placement for IOPLL with DIB of Stratix 10.
I got the next Error from the Fitter while trying to synthesis with DIB
The Fitter Failed to find legal placement for my IOPLL
is there a way to find out which PLL is preferred by the DIB , or vise versa any methodical way to find out which DIB subsystem / channel or bank I choose - since I know what are my free PLL.
(BTW I have many free pll, but somehow they does not good enough for usage by the fitter due to DIB location )
this is the Error I get:
Error (14996): The Fitter failed to find a legal placement for all periphery components
Error (14986): After placing as many components as possible, the following errors remain:
Error (175001): The Fitter cannot place 1 IOPLL.
Info (14596): Information about the failing component(s):
Info (175028): The IOPLL name(s): f1|cnvr_dib_rx_pll_inst|iopll_0|stratix10_altera_iopll_i|s10_iopll.fourteennm_pll
Error (16234): No legal location could be found out of 24 considered location(s). Reasons why each location could not be used are summarized below:
Error (175006): There is no routing connectivity between source DIB_DIB_PHY and the IOPLL
Info (175026): Source: DIB_DIB_PHY f1|cnvr_dib_wrapper_ins|dib_rx_2_22|dib_0|dib_ch|arch_inst|phy_inst|xphy_inst
Info (175013): The DIB_DIB_PHY is constrained to the region (442, 290) to (442, 290) due to related logic
Info (175015): The I/O pad DIE1_dib_pad_2_22_0[0] is constrained to the location PIN_DIB0_CH22_X1Y2 due to: User Location Constraints (PIN_DIB0_CH22_X1Y2)
Info (14709): The constrained I/O pad contains this DIB_DIB_PHY
Info (175015): The I/O pad DIE1_dib_pad_2_22_3[22] is constrained to the location PIN_DIB94_CH22_X1Y2 due to: User Location Constraints (PIN_DIB94_CH22_X1Y2)
Info (14709): The constrained I/O pad drives a DIB_DIB_IO_WRP, which drives this DIB_DIB_PHY
Info (175021): The DIB_DIB_PHY was placed in location DIBDIBPHY_X442_Y290_N1
Error (175022): The IOPLL could not be placed in any location to satisfy its connectivity requirements
- AqidAyman_Altera
Alright, I understand.
I think you may right which the design might be not supported.
Aqid
- OrF
Yes , I read this guideline .
this guideline presents the DIB solution and explain the clocks transfer of the DIB itself , it does not explain how to transfer clock from one side other side. this is different design solution , which means that my design should transfer its data without its clock. the data itsefl will be sync by the DIB clock
Or.
- AqidAyman_Altera
Hi Or,
Have you check this guideline?
It mentioned that "the DIB subsystem sends a source synchronous clock to another DIB subsystem in the adjacent die (TX or RX). In Synchronous mode, the system clock is synchronous to the DIB clock."
Aqid
- AqidAyman_Altera
Hi Or,
Apologies as I am did not aware that clocks are being transferred to another die via DIB.
Have you tried to provide the input clock signal to the IOPLL through dedicated clock pins?
Aqid
- OrF
I didn't try because my design is Source-synchronous , clock is coming WITH the data.
it seems that Intel does not support "Source-synchronous" via DIB and it is not written any where ...
Or.
- AqidAyman_Altera
Hi Or,
Apologies for the delay. I have several tasks and make me overlook for this. I am still trying to fix the error.
Can you follow this guideline as below link and see if the error still remains?
https://www.intel.com/content/www/us/en/docs/programmable/683142/20-2-19-3-0/clocking-options.html
Aqid
- OrF
Hi Aqid
I don't see any relation to my issue with the suggested guideline.
1. in the document you send , it is about clock/pll which "Feeds" the DIB, in my case the the PLL is Feed by a clock which transfer from the other die via the DIB "Source-synchronous" architecture, the the clock which arrives from the DIB is feeding the PLL ...
2. more over , if I would like learn from the document you sent , it does not say anything how to choose specific pll. which might solve the Fitter issues.
if you can please elaborate what did you mean , that I should follow this guideline in my design , since I don't find any relation to my issue, or something I can do.
Or.
- AqidAyman_Altera
Okay got it. I managed to reproduce the error from my side. I will start with debugging and communicate back with you if I have any findings.
- AqidAyman_Altera
As for now, I am not getting your reply yet.
- OrF
I sent 2 times to the support did you get it eventually ?
- AqidAyman_Altera
Hi Or,
I have replied through email. Can you see it now?
Aqid
- OrF
got your mail , and put the path to qar file .
reply to email (Intel Customer Support <[email protected]>)
Or.
- AqidAyman_Altera
Hi Or,
I have initiated an email for you. You can share the .qar file through that. Kindly check your inbox.
Aqid
- OrF
Hi I answered in the email , but didn't get any reply so I post here as well..
the QAR file is very big , and since I'm Intel employee can you share a place I can upload the QAR file ?
Or.
- OrF
I prefer to share the data base privately , to where can I upload it ? (inside intel right ? ) what is the file (QAR, Quartos Archive file )?
Or.
