15 years ago
testbench integer type
Dear all,
Below is my testbench code that i simulate in ModelSim.
library IEEE;
use IEEE.Std_logic_1164.all;
use IEEE.Numeric_Std.all;
entity reg_tb is
end;
architecture bench of reg_tb is
component reg
PORT (
input : IN integer RANGE -127 TO 127;
clk : IN bit;
output : OUT integer RANGE -127 TO 127
end component;
signal input: integer RANGE -127 TO 127;
signal clk: bit;
signal output: integer RANGE -127 TO 127 ;
constant clock_period: time := 10 ns;
signal stop_the_clock: boolean;
begin
uut: reg port map ( input => input,
clk => clk,
output => output );
stimulus: process
begin
-- Put initialisation code here
input <= "3";
clk <= "0";
wait for 100ns;
input <= "12";
clk <= "1";
wait for 100ns;
stop_the_clock <= true;
wait;
end process;
clocking: process
begin
while not stop_the_clock loop
clk <= '0', '1' after clock_period / 2;
wait for clock_period;
end loop;
wait;
end process;
end;
This is the error:
Error (10515): VHDL type mismatch error at reg_tb.vhd(35): integer type does not match string literal
Can anyone tell me, where I'm wrong..Many thanks
