15 years agotestbench integer type
Dear all, Below is my testbench code that i simulate in ModelSim. --------------------------------------------------------------------- library IEEE; use IEEE.Std_logic_1164.all; use IE...
15 years agoDear Tricky,
I has instantiate the haar.vhd file and also compile all others file in to library. But, when I run it, the input is correct but no output is obtained. I don't know why. Below is my haar testbench code: --------------------------------------------------------------------------- library IEEE; use IEEE.Std_logic_1164.all; use IEEE.Numeric_Std.all; entity haar_tb is end; architecture bench of haar_tb is -------------Component Declarations--------------- component haar PORT ( clock : IN bit; in1 : IN integer RANGE -127 TO 127; in2 : IN integer RANGE -127 TO 127; in3 : IN integer RANGE -127 TO 127; in4 : IN integer RANGE -127 TO 127; in5 : IN integer RANGE -127 TO 127; in6 : IN integer RANGE -127 TO 127; in7 : IN integer RANGE -127 TO 127; in8 : IN integer RANGE -127 TO 127; out1 : OUT integer RANGE -127 TO 127; out2 : OUT integer RANGE -127 TO 127; out3 : OUT integer RANGE -127 TO 127; out4 : OUT integer RANGE -127 TO 127; out5 : OUT integer RANGE -127 TO 127; out6 : OUT integer RANGE -127 TO 127; out7 : OUT integer RANGE -127 TO 127; out8 : OUT integer RANGE -127 TO 127 ); end component; --------------Signal Declarations----------------- signal clock: bit; signal in1: integer RANGE -127 TO 127; signal in2: integer RANGE -127 TO 127; signal in3: integer RANGE -127 TO 127; signal in4: integer RANGE -127 TO 127; signal in5: integer RANGE -127 TO 127; signal in6: integer RANGE -127 TO 127; signal in7: integer RANGE -127 TO 127; signal in8: integer RANGE -127 TO 127; signal out1: integer RANGE -127 TO 127; signal out2: integer RANGE -127 TO 127; signal out3: integer RANGE -127 TO 127; signal out4: integer RANGE -127 TO 127; signal out5: integer RANGE -127 TO 127; signal out6: integer RANGE -127 TO 127; signal out7: integer RANGE -127 TO 127; signal out8: integer RANGE -127 TO 127 ; begin ---------------Component Instantiation-------------- uut: haar port map ( clock => clock, in1 => in1, in2 => in2, in3 => in3, in4 => in4, in5 => in5, in6 => in6, in7 => in7, in8 => in8, out1 => out1, out2 => out2, out3 => out3, out4 => out4, out5 => out5, out6 => out6, out7 => out7, out8 => out8 ); stimulus: process begin ---------------------First Test------------------ in1 <= 18; in2 <= 5; in3 <= 1; in4 <= 9; in5 <= 13; in6 <= 6; in7 <= 2; in8 <= 3; wait for 50ns; ---------------------Second Test------------------ in1 <= 10; in2 <= 2; in3 <= 3; in4 <= 4; in5 <= 15; in6 <= 7; in7 <= 13; in8 <= 8; wait for 50ns; ---------------------Third Test-------------------- in1 <= 1; in2 <= 3; in3 <= 11; in4 <= 8; in5 <= 15; in6 <= 4; in7 <= 6; in8 <= 13; wait for 50ns; wait; end process; end; Can you tell me, what I'm missing...Many thanks
