17 years ago
Stratix III EP3SL340c3 Diffrential IO data rate
Hi
I have been working on DE3 board with the above mentioned FPGA for some months now. I am trying to deserialize 8 LVDS channels from an ADC. each channel is 12 bits and ADC can work upto 50 Mega Samples per second. I am designing my own Deserializing circuit because there are not enough PLLs on DE3 FPGA ( i will interfacing 12 ADCs where as there are only 8 PLLs on FPGA) and each SERDES Megafunction requires 1 PLL.
I am trying to operate IO pins at (max) 600 Mbits per second and my shift registers are working at half the bit rate i.e. 300 mega shifts per seconed (as each channel has 2 shift registers, 1 for even stream of bits and other one for odd. In the end i interleave two streams).
I have tried many different design approaches along with playing arround with chip planner defining regions, assigning specific resources to different instances and so on... but each of my design fails at arround 25 Mega Samples. Simulation shows a picture perfect scenario even at 50 MHz. I was wondering if IO pins are creating the bottle neck here or is it the shift registers in my design. ( i am using LPM_SHIFTREG megafunction for shift registers)
If anyone can provide me some idea about where the problem could be, i would be greatful.
    What speed grade device is on the DE3 board? 600Mbps on an input port is pretty fast, as you've only got a 1.666ns bit period.
    My second concern is that, being limited by the board you're using, a number of the clocks will be coming in on regular I/O. That means you're going to use local routing to get to all the I/O in the databus, which means the delay to every I/O will be different. If you're timing constraints are correct, then the Quartus II fitter will modify the delay chains on the input registers to center the data onto the clock edge, but it can only do so much.
    My third concern is that, without a PLL, you're raw clock delay variance will be too large. For example, let's say it takes 3ns for the clock to route to the I/O, which is pretty fast. That's 3ns in the slow corner timing model. In the fast corner model it could easily be half that, especially in the slowest speed grade, so that means your clock delay could vary between 1.5ns and 3ns over PVT, which is pretty much the whole data eye. I'm making these numbers up, but you get the point. A PLL's feedback loop is designed to eliminate PVT variance on the clock tree, which makes I/O timing on fast interfaces much more feasible.
    So I don't think it's a logical issue, but a timing issue, that will be the problem. I haven't built anythign up and tested it out, but have serious concerns.
    Let me know if any of that doesn't make sense.
    Hi FvM,
    Unfortunately i cant use 1 PLL with multiple ADCs as each ADC is on a separate board with its own connector. I have designed a Back Plane PCB which splits each HSTC Connector's IO pins only (no dedicated clock pins) to 3 small connectors (for 3 ADC). Thus 4 HSTCs provide me with 12 connectors for ADCs, none of which share pins on the FPGA. Also HSTC on DE3 has only 4 dedicated clock pins (thats y i didnt use them) and quartus wont let me connect PLL to a normal IO pin.
    "Alternatively, you can use the bitclock output from ADC as SERDES clock and no PLL at all."
    Well this might work. Only worry i have is if the Bitclock will have enough fanout to support SERDES as it is using a normal IO pin instead of a dedicated clock pin.
    EDIT
    "Hmmm. Just tried ALTLVDS megafunction. The slow clock has a dutycycle recuirement of 8.33%. One from my ADC is 50%. So i dont know if this approach will work..."
    I don't think, that you need a PLL for each ADC. You may use a PLL output for each ADC, if you want to adjust the receiving phase for each ADC individually, which shouldn't be necessary normally. At least, you should provide a common phase adjustment for the fast SERDES clock (300 MHz) for all ADCs. Alternatively, you can use the bitclock output from ADC as SERDES clock and no PLL at all. Personally, I prefer the PLL variant.
    The SERDES should use an altddio_in block as 1:2 demux. Than a single SR, shifting in two bits for each fastclock edge, can be used. It has no problem to achieve 600 MBPS rate with CIII.
    A user designed SERDES can provide deserialization factors, that aren't directly supported by the altlvds MegaFuntion with CIII, e.g. 12 and 14. It also allows a clearer configuration of timing parameters.
    P.S.: Utilizing the test pattern option of LVDS ADC and PLL dynamic phase shift, an automatic SERDES phase calibration can be realized.
