17 years agoStratix III EP3SL340c3 Diffrential IO data rate
Hi I have been working on DE3 board with the above mentioned FPGA for some months now. I am trying to deserialize 8 LVDS channels from an ADC. each channel is 12 bits and ADC can work upto 50 Mega...
17 years agoHi FvM,
Unfortunately i cant use 1 PLL with multiple ADCs as each ADC is on a separate board with its own connector. I have designed a Back Plane PCB which splits each HSTC Connector's IO pins only (no dedicated clock pins) to 3 small connectors (for 3 ADC). Thus 4 HSTCs provide me with 12 connectors for ADCs, none of which share pins on the FPGA. Also HSTC on DE3 has only 4 dedicated clock pins (thats y i didnt use them) and quartus wont let me connect PLL to a normal IO pin. "Alternatively, you can use the bitclock output from ADC as SERDES clock and no PLL at all." Well this might work. Only worry i have is if the Bitclock will have enough fanout to support SERDES as it is using a normal IO pin instead of a dedicated clock pin. EDIT "Hmmm. Just tried ALTLVDS megafunction. The slow clock has a dutycycle recuirement of 8.33%. One from my ADC is 50%. So i dont know if this approach will work..." Thanks
