15 years ago
SRAM model Generation
Hello
I have a NIOSII system as follow :
EPCS controller
CPU - tristate-Bridge - sram_ctrl_v00
+ some other bits
my SRAM is external to the FPGA. So I have created a controller sram_ctrl_v00
my sram_ctrl_v00 is an Avalon Memory Mapped Tri state Slave, describe in sram_ctrl_v00.tcl.
I found a model of the sram (in the enclosed zip file).
I don't really know how to include the model so it can be used with modelsim. (is it during create custom component ?...)
When I use eclipse , if I set all my code in SRAM , it will never generate the hex file associated with the SRAM (mem_init install or mem_init_generate). I would expect sram_ctrl_v00.hex
Can somebody help please ?
Ben
    What is the difference between the following code and the real sar controller?
    --- Quote Start ---
    library IEEE;
    use IEEE.std_logic_1164.all;
    use IEEE.numeric_std.all;
    entity sram1024kx8 is
    port (A : in Std_logic_vector(19 downto 0);
    D : inout Std_logic_vector(7 downto 0);
    nCE : in std_logic;
    nCE2 : in std_logic;
    nWE : in std_logic;
    nOE : in Std_logic);
    end;
    architecture Behaviour of sram1024kx8 is
    subtype Byte is Std_logic_vector(7 downto 0);
    type Mem is array (0 to 1048576 ) of byte;
    signal Memory: Mem := (others => Byte'(others=>'U'));
    begin
    process(A, D, nCE, nCE2, nWE, nOE)
    begin
    D <= (others => 'Z');
    if nCE='0' and nCE2='0' then
    if nOE = '0' then -- Read operation
    D <= Memory(To_Integer(unsigned(A))) after 10 ns;
    elsif nWE = '0' then -- Write operation
    Memory(To_Integer(unsigned(A))) <= D;
    end if;
    end if;
    end process;
    end;
    --- Quote End ---
    Please I can't get the relationship between the both I thought it was enough ?
    Do you have an example so that I could based on this ?
    Hi ben,
    I also need to integrate a custom memory in my prjoject. But I don't have idea how the memory controller should look like. I already implemented the model and testbench for Cypress 1024x8 Bit memory.
    Can you please share me a piece of code to get an overview ?
    Hello
    The model need to be included in the file that represent your NIOS (at the bottom of the file).
    You will find locations where you can include your code :
    -- <Altera_Note>.....
    The code will not be removed when you re generate your NIOS II system.
    This is the idea.
    To check my design , I had no time to perform what is described above, but this is the philosophy. Instead , I have used the internal memory under Modelsim , and use SDRAM in the real product.
    This was to be able to check a full design (NIOS + Logic) together.
    Also , you will have to set the NIOS II software/BSP (under Eclipse) to generate the correct file for SDRAM or Internal Mem.
    Ben
    Hello ,
    Please I am facing the same problem can you give me some advice on interfacing external memory:
    I wrote a memory model+testbench+controller
    How should I move forward?
    I would appreciate any advice...
