15 years agoSRAM model Generation
Hello I have a NIOSII system as follow : EPCS controller CPU - tristate-Bridge - sram_ctrl_v00 + some other bits my SRAM is external to the FPGA. So I have created a controller sra...
14 years agoWhat is the difference between the following code and the real sar controller?
--- Quote Start --- library IEEE; use IEEE.std_logic_1164.all; use IEEE.numeric_std.all; entity sram1024kx8 is port (A : in Std_logic_vector(19 downto 0); D : inout Std_logic_vector(7 downto 0); nCE : in std_logic; nCE2 : in std_logic; nWE : in std_logic; nOE : in Std_logic); end; architecture Behaviour of sram1024kx8 is subtype Byte is Std_logic_vector(7 downto 0); type Mem is array (0 to 1048576 ) of byte; signal Memory: Mem := (others => Byte'(others=>'U')); begin process(A, D, nCE, nCE2, nWE, nOE) begin D <= (others => 'Z'); if nCE='0' and nCE2='0' then if nOE = '0' then -- Read operation D <= Memory(To_Integer(unsigned(A))) after 10 ns; elsif nWE = '0' then -- Write operation Memory(To_Integer(unsigned(A))) <= D; end if; end if; end process; end; --- Quote End --- Please I can't get the relationship between the both I thought it was enough ? Do you have an example so that I could based on this ?
