ohfpga1's avatar
ohfpga1
4 months ago
Agilex5 - Timings configuration
in document 813918, I have a question regrading method to define NOR timing, table 115, using Text_delay as conditions for input timings.
this parameter is said dependant  of frequency of interface (note 195), but only one value (max) is given (no min), and this one is greater than half-period and even at clock frequency 166MHz which seems to be considered by datasheet. I don't understand.
Can we get simply Setup and Hold timings for Agilex inputs for AS configuration interface ?
Thanks and regards
  • Farabi_Altera's avatar
    Farabi_Altera
    To answer your question:
    Table 115 : AS timing parameters is not a setup/hold guarantee table, instead, it is a board-level interface contstraint table, to calculate FPGA + flash + PCB delays.
    Most imporatantly, we need to interpret the skew equation:
    AS_CLK vs AS_DATA : AS_CLK/2 + Tdo(max) + Tsu < Skew (AS_CLKAS_DATA) < AS_CLK/2 + Tdo(min) – Tho
    Above equation is not setup/hold spec, but relative arrival window.
    summary above equation:
    AS_DATA can arrive before or after AS_CLK as long as the skew is bounded.
    Reason why Altera dont publish setup/hold time for AS inputs
    a) AS configuration pins are handled by dedicated IOs
    b) Not routed to user IO
    c) exist in different clock domain
    While internal margins are:
    a) characterized
    b) guard-band
    c) hidden from user
    Altera guarantee the correct operation if you meet the skew rules, instead of publishing internal setup/hold time spec.
    regards,
    Farabi
  • ohfpga1's avatar
    ohfpga1
    Hi Farabi, thanks a lot for your detailed answer.
    • FakhrulA_altera's avatar
      FakhrulA_altera
      I’m glad that your question has been addressed, I now transition this thread to community support. This thread will be transitioned to community support. If you have a new question, feel free to open a new thread to get support from Altera experts. Otherwise, the community users will continue to help you on this thread. Thank you.
