Agilex5 - Timings configuration
To answer your question:
Table 115 : AS timing parameters is not a setup/hold guarantee table, instead, it is a board-level interface contstraint table, to calculate FPGA + flash + PCB delays.
Most imporatantly, we need to interpret the skew equation:
AS_CLK vs AS_DATA : –AS_CLK/2 + Tdo(max) + Tsu < Skew (AS_CLK – AS_DATA) < AS_CLK/2 + Tdo(min) – Tho
Above equation is not setup/hold spec, but relative arrival window.
summary above equation:
AS_DATA can arrive before or after AS_CLK as long as the skew is bounded.
Reason why Altera dont publish setup/hold time for AS inputs
a) AS configuration pins are handled by dedicated IOs
b) Not routed to user IO
c) exist in different clock domain
While internal margins are:
a) characterized
b) guard-band
c) hidden from user
Altera guarantee the correct operation if you meet the skew rules, instead of publishing internal setup/hold time spec.
regards,
Farabi
