SK_VA's avatar
SK_VA
5 years ago
SPI Slave Timing Constraints
I have an SPI slave implemented in FPGA with input SCLK clock ranging between 10-20MHz.
I have added two flop synchronizer for all SPI input signals CS,SCLK,MOSI before using them in the Slave logic.The two flop synchroniser operates at a very high frequency of 100MHz.
I saw in one of the altera forum posts that SPI slave where all the inputs are synchronized with a double register-chain doesn't need to be constrained.
But if I set them as false path how does the fitter know the timing relation between SCLK,MISO and MOSI. Do we need to consider SPI as a source synchronous interface?
How to estimate the setup and clock to output timing of this interface?
  • KhaiChein_Y_Intel's avatar
    KhaiChein_Y_Intel
    You have to constrain the virtual clock that connect to the clock pin of the source data signal.
    KhaiY
      KhaiChein_Y_Intel
      We do not receive any response from you to the previous question/reply/answer that I have provided. This thread will be transitioned to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you
      KhaiY
    • SK_VA's avatar
      SK_VA
      I am using a two flop synchronizer that runs at a higher frequency for all the SPI slave inputs including clock. Do I need to constrain with a virtual clock of higher frequency or wrt spi slave clock input as source synchronous.
