8 years ago
SPI ram and Nios on FPGA MAX10
Hi all,
Is it possible connect a SPI ram (single or quad) to the NiosII in Qsys and allocate/use (from C code in Eclipse) my data in this ram?
Thanks in advance.
Perryiavo
    Yes,
    I would like a hardware module that allows NiosII to see the external SPI ram as regular RAM (obviously slower then a real RAM).
    I resolved this problem: I wrote my hardware module (in VHDL) and I used a Avalon-MM Pipelined Bridge to export the Avalon-MM bus to this module (extern to NiosII).
    This module manages on one hand the interfacing with NiosII (raises the waitrequest signal in order to stop the execution of the code until it has completed the operation with external RAM, asserts data for the read operations etc. etc.) and on the other hand manages the communication from/towards the external SPI ram according to the rules of the ram itself.
    In the application code of NiosII (C code) I allocate in the address space provided by the Avalon-MM Pipelined Bridge the variables, the stack and all the rest of my application (apart from the exception code that I run in the internal ram for reasons of execution speed).
    Perryiavo.
    • ASidd16's avatar
      ASidd16
      I'm also looking for the solution, can you please explain more.
      Thank you
    The OP is talking about an SPI ram, not an SDRAM. None of the documentation you pointed to is relevant.
    As far as I know there isn't any ready available module for what you want to do. If you use a generic SPI master IP, you will have to write a software driver and manually send commands to the RAM and read back the results.
    If I understood your post correctly, you'd rather like a hardware module that will make the SPI ram directly available to the Nios II CPU as if it was a regular RAM. I'm afraid you will have to write this yourself.
    Hi Perryiavo,
    Again, apologize in advance since I’m not the expert in NIOS application. I think you can use the SDRAM IP together with the NIOS II in the Qsys to communicate with the external RAM memory. Refer to the Embbededd IP user guide from the following link for the SDRAM IP usage:
    https://www.altera.com/content/dam/altera-www/global/en_us/pdfs/literature/ug/ug_embedded_ip.pdf
    nyusof
    --- Quote Start ---
    Hi Perryiavo,
    Apologize in advance since I’m not really expert in NIOS application. However as far I know in general, it is possible to use an external RAM with Nios II to execute your data/C code. You can refer to the AN730 on this:
    https://www.altera.com/en_us/pdfs/literature/an/an730.pdf
    nyusof
    --- Quote End ---
    Yes,
    I have already seen that document but my problem is to communicate with the ram on SPI.
    I would make a bridge between avalon MM bus and SPI.
    Is it possible? If yes, how?
    Hi Perryiavo,
    nyusof
