8 years agoSPI ram and Nios on FPGA MAX10
Hi all, Is it possible connect a SPI ram (single or quad) to the NiosII in Qsys and allocate/use (from C code in Eclipse) my data in this ram? Thanks in advance. Perryiavo
8 years agoHi Perryiavo,
Again, apologize in advance since I’m not the expert in NIOS application. I think you can use the SDRAM IP together with the NIOS II in the Qsys to communicate with the external RAM memory. Refer to the Embbededd IP user guide from the following link for the SDRAM IP usage: https://www.altera.com/content/dam/altera-www/global/en_us/pdfs/literature/ug/ug_embedded_ip.pdf Regards, nyusof (This message was posted on behalf of Intel Corporation)
