8 years agoSPI ram and Nios on FPGA MAX10
Hi all, Is it possible connect a SPI ram (single or quad) to the NiosII in Qsys and allocate/use (from C code in Eclipse) my data in this ram? Thanks in advance. Perryiavo
8 years agoThe OP is talking about an SPI ram, not an SDRAM. None of the documentation you pointed to is relevant.
As far as I know there isn't any ready available module for what you want to do. If you use a generic SPI master IP, you will have to write a software driver and manually send commands to the RAM and read back the results. If I understood your post correctly, you'd rather like a hardware module that will make the SPI ram directly available to the Nios II CPU as if it was a regular RAM. I'm afraid you will have to write this yourself.
