--- Quote Start ---
@ Kevin
too bad that the nios forum lost the thread, there was a list what devices were working (without any modification)
--- Quote End ---
Michael,
Have you searched the Google cache for the lost pages? I had a go and found a lot of threads (some by you) but wasn't sure which one you were referring to. Here's the content of one possibility:
--- Quote Start ---
Today i have replaced an Altera EPCS by a Spansion S25FL064A0LMFI001
If, as mentioned bevore here, flash override has the following entry :
[EPCS-010216]# EPCS64N (Spansion-lead-free) S25FL064A0LMFI001
sector_size = 65536
sector_count = 128
I can successfully Blaster this device and will receive the following output :
EPCS signature is 0x16
EPCS identifier is 0x010216
Using EPCS size information from section [EPCS-010216]
Device size is 8MByte (64Mbit)
Erase regions are:
offset 0: 128 x 64K
In Addition i have replace an EPCS16SI8N by Numonyx M25P16-VMN6P
EPCS signature is 0x14
EPCS identifier is 0x202015
Using EPCS size information from section [EPCS-202015]
Device size is 2MByte (16Mbit)
Erase regions are:
offset 0: 32 x 64K
So M25P16-VMN6P is detected as EPCS16SI8N and can be blasterd too, what tells us that ....
Thanks for all replies now i have some much cheaper first choices and a good proven Altera second source :-)
Michael
--- Quote End ---
Cheers
