17 years agoSPI Flash devices
I am looking for a SPI FLASH device to configure a Cyclone III device in AS mode. I know that other manufacturers make FLASH parts that are compatible with the Altera EPCSx series, but Altera does n...
16 years ago --- Quote Start --- EPCS ID check can be disabled in jic generation. Isn't that sufficient? --- Quote End --- Sorry, dumb question, but what is JIC? Is disabling the EPCS ID Check something in the IDE or something done in code? --- Quote Start --- add a file called nios2-flash-override.txt and place it in folder ..\nios2eds\bin this file should have the following [epcs-010216]# epcs64n (spansion-lead-free) s25fl064a0lmfi001
sector_size = 65536
sector_count = 128
--- Quote End --- Does adding a file like this for a particular SPI flash, work only if you're flashing an epcs via the Nios IDE, or will it work programmatically (i.e. via nios code) as well? Cheers!
