17 years agoSPI Flash devices
I am looking for a SPI FLASH device to configure a Cyclone III device in AS mode. I know that other manufacturers make FLASH parts that are compatible with the Altera EPCSx series, but Altera does n...
17 years ago --- Quote Start --- @ Kevin too bad that the nios forum lost the thread, there was a list what devices were working (without any modification) --- Quote End --- Michael, Have you searched the Google cache for the lost pages? I had a go and found a lot of threads (some by you) but wasn't sure which one you were referring to. Here's the content of one possibility: --- Quote Start --- Today i have replaced an Altera EPCS by a Spansion S25FL064A0LMFI001 If, as mentioned bevore here, flash override has the following entry : [EPCS-010216]# EPCS64N (Spansion-lead-free) S25FL064A0LMFI001 sector_size = 65536 sector_count = 128 I can successfully Blaster this device and will receive the following output : EPCS signature is 0x16 EPCS identifier is 0x010216 Using EPCS size information from section [EPCS-010216] Device size is 8MByte (64Mbit) Erase regions are: offset 0: 128 x 64K In Addition i have replace an EPCS16SI8N by Numonyx M25P16-VMN6P EPCS signature is 0x14 EPCS identifier is 0x202015 Using EPCS size information from section [EPCS-202015] Device size is 2MByte (16Mbit) Erase regions are: offset 0: 32 x 64K So M25P16-VMN6P is detected as EPCS16SI8N and can be blasterd too, what tells us that .... Thanks for all replies now i have some much cheaper first choices and a good proven Altera second source :-) Michael --- Quote End --- Cheers
