17 years agoSPI Flash devices
I am looking for a SPI FLASH device to configure a Cyclone III device in AS mode. I know that other manufacturers make FLASH parts that are compatible with the Altera EPCSx series, but Altera does n...
16 years agothis override file is only intended to be used with the command line nios2-flash-programmer --epcs but to honest i am unshure if the ide would also use it and might call nios2-flash-programmer as i do not use the ide.
you need this if want to store your fpga and or application image into an epcs device that is not known to nios2-flash-programmer like the spansion type
