17 years agoSPI Flash devices
I am looking for a SPI FLASH device to configure a Cyclone III device in AS mode. I know that other manufacturers make FLASH parts that are compatible with the Altera EPCSx series, but Altera does n...
16 years agoDo you know, if the NIOS programmer is able to handle the 4K sector erase in constrast to 32k block erase? The latter should work at least, because the Atmel device is compatible to EPCS1 when using large blocks.
