17 years agoSPI Flash devices
I am looking for a SPI FLASH device to configure a Cyclone III device in AS mode. I know that other manufacturers make FLASH parts that are compatible with the Altera EPCSx series, but Altera does n...
16 years agoi'm trying to use the AT25FS010 ATMEL SPI FLASH so i insert the file
nios2-flash-override.txt and within there is: [EPCS-1F6601]# EPCS1N (ATMEL SPI FLASH) S25FL064A0LMFI001 sector_size = 4096 sector_count = 32 but the result is: [NiosII EDS]$ nios2-flash-programmer --epcs --base=0x00002000 "spi_flash.flash" --verbose Reading override file "c:/altera/90/nios2eds/bin/nios2-flash-override.txt" Using cable "USB-Blaster [USB-0]", device 1, instance 0x00 Resetting and pausing target processor: OK Processor data bus width is 32 bits Looking for EPCS registers at address 0x00002000 (with 32bit alignment) Initial values: 0001703A 04C00074 9801483A 9CFFF804 983FFD1E 0000203A Not here: reserved fields are non-zero Looking for EPCS registers at address 0x00002100 (with 32bit alignment) Initial values: 92400237 4A40100C 483FFD26 90000135 92400237 4A40200C Not here: reserved fields are non-zero Looking for EPCS registers at address 0x00002200 (with 32bit alignment) Initial values: 03803904 73C00136 00000406 03803C44 7BBF9336 03803DC4 Not here: reserved fields are non-zero Looking for EPCS registers at address 0x00002300 (with 32bit alignment) Initial values: 00000000 00000000 00000000 00000000 00000000 00000000 Not here: SPI_SLAVE_SEL has 0 valid bits (should be between 1 and 16) Looking for EPCS registers at address 0x00002400 (with 32bit alignment) Initial values: 00000000 00000000 00000260 00000000 00000000 00000001 Valid registers found EPCS signature is 0x1F EPCS identifier is 0x1F6601 Using EPCS size information from section [EPCS-1F6601] Device size is 128KByte (1Mbit) Erase regions are: offset 0: 32 x 4K EPCS status is 0x00 : Checksumming existing contents 00000000 : Verifying existing contents 00000000 : Needs erase then program 00001000 : Verifying existing contents 00001000 : Needs erase then program 00002000 : Verifying existing contents 00002000 : Needs erase then program 00003000 : Verifying existing contents 00003000 : Needs erase then program 00004000 : Verifying existing contents 00004000 : Needs erase then program 00005000 : Verifying existing contents 00005000 : Needs erase then program 00006000 : Verifying existing contents 00006000 : Needs erase then program 00007000 : Verifying existing contents 00007000 : Needs erase then program 00008000 : Verifying existing contents 00008000 : Needs erase then program 00009000 : Verifying existing contents 00009000 : Needs erase then program 0000A000 : Verifying existing contents 0000A000 : Needs erase then program 0000B000 : Verifying existing contents 0000B000 : Needs erase then program 0000C000 : Verifying existing contents 0000C000 : Needs erase then program 0000D000 : Verifying existing contents 0000D000 : Needs erase then program 0000E000 : Verifying existing contents 0000E000 : Needs erase then program 00000000 : Reading existing contents 00001000 : Reading existing contents 00002000 : Reading existing contents 00003000 : Reading existing contents 00004000 : Reading existing contents 00005000 : Reading existing contents 00006000 : Reading existing contents 00007000 : Reading existing contents 00008000 : Reading existing contents 00009000 : Reading existing contents 0000A000 : Reading existing contents 0000B000 : Reading existing contents 0000C000 : Reading existing contents 0000D000 : Reading existing contents 0000E000 : Reading existing contents Checksummed/read 1kB in 0.0s 00000000 ( 0%): Erasing Erase failed at offset 0 Leaving target processor paused did i miss some steps?
