12 years agosorter in vhdl
hi every one
i want avhdl code to sort integer input ascending if i have an array such as 1,8,9,7,2 the out put will be such as 1,2,7,8,9 i search a lot but didn't find any code that helping me thanks .40 Replies
--- Quote Start --- no , i will get a large number of data but, if you may remember i want the sorted trigraphs (codes) to compute the distances between two trigraphs ,do you remember?? so,i want it to be in a single output (independent) not including in the ram content i hope you understand me --- Quote End --- do you mean like this:(then you need to discard any zero outputs)library ieee; use ieee.std_logic_1164.all; use IEEE.numeric_std.all; entity bubblesort is port( clk : in std_logic; we : in std_logic := '1'; trigraph : in std_logic_vector(7 downto 0) := x"0F"; duration : in integer range 0 to 1023 := 5; read : in std_logic := '0'; dout : out std_logic_vector(7 downto 0) ); end entity; architecture rtl of bubblesort is signal address, rd_addr : integer range 0 to 1023 := 0; type mem is array(0 to 1023) of std_logic_vector(7 downto 0); signal ram : mem := ((others=> (others=>'0'))); begin --infer ram process(clk) begin if(rising_edge(clk)) then dout <= ram(address); if(we = '1') then ram(address) <= trigraph; end if; end if; end process; process(clk) begin if rising_edge(clk) then if read = '1' then if rd_addr < 1023 then rd_addr <= rd_addr + 1; end if; end if; if read = '0' then address <= duration; else address <= rd_addr; end if; end if; end process; end rtl ; - Altera_Forum
--- Quote Start --- if you pick up only those write addresses for read as well then it defeats the purpose as we want to read in the full order of addressing. If it slow you can use faster rate. The alternative to be considered is this: If your data set is small then you can implement your memory as registers in the fabric (hence addressable all at any time), I mean a 2D register, each register set will have index (as address e.g. 0 ~ 15 ). Once you write to these registers you can check nonzero data from index zero to 15 in one clock and then decide to read out only those with nonzero data in succession. --- Quote End --- no , i will get a large number of data but, if you may remember i want the sorted trigraphs (codes) to compute the distances between two trigraphs ,do you remember?? so,i want it to be in a single output (independent) not including in the ram content i hope you understand me - Altera_Forum
--- Quote Start --- do you have a look to 2nd picture i need to get the output trigraph alone because i will use it how can i do it?? --- Quote End --- if you pick up only those write addresses for read as well then it defeats the purpose as we want to read in the full order of addressing. If it slow you can use faster rate. The alternative to be considered is this: If your data set is small then you can implement your memory as registers in the fabric (hence addressable all at any time), I mean a 2D register, each register set will have index (as address e.g. 0 ~ 15 ). Once you write to these registers you can check nonzero data from index zero to 15 in one clock and then decide to read out only those with nonzero data in succession. - Altera_Forum
i need to get the output trigraph alone because i will use it how can i do it?? - Altera_Forum
You need to run address from 0 to 1023 after you write all your data.
currently you are reading all addresses when they are still zeros(not updated) except last one. so you simulation is ok but you need more work to read all addresses and ignore any address that has zero data. - Altera_Forum
I missed that you suggested a content associative memory (CAM). I agree that it's a straightforward method for small numbers, e.g. 8 bit wide as specified by the OP.
Thanks for clarifying. - Altera_Forum
--- Quote Start --- I think you can either sort the entries in RAM (e.g. using the well-known bubble sort algorithm), or build up an index table and output a sorted stream using this index. I don't see a third method. But anyway, let's look for the results. --- Quote End --- The post is about two streams of data (duration and code). if I have one stream e.g. : 2,6,1,0,7,9,14,1,3,1,6 ...etc I can sort it using one ram of say depth 16, 3 bit width. each data arrives as address, I run counter on the 3 bits data(read 0, increment, write back into ram) thus I get in the ram at the end of data set: location:data 0: 1 1:3 2:1 3:1 4:0 5:0 6:2 7:1 8:0 9:1 10:0 11:0 12:0 13:0 14:1 15:0 hence when I read ram back in ascending address order I get: 0,1,1,1,2,3,6,6,7,9,14 I think it is sorted now - Altera_Forum
--- Quote Start --- we are not exchanging ram entries but want to sort som data in ascending order to output. --- Quote End --- I think you can either sort the entries in RAM (e.g. using the well-known bubble sort algorithm), or build up an index table and output a sorted stream using this index. I don't see a third method. But anyway, let's look for the results. - Altera_Forum
--- Quote Start --- exactly what i want ,but how i can get the addresses ordered in a single output and the corresponding codes that ordered in another output how i can make it in separate way?? --- Quote End --- In my example you will get two outputs(addr and data): addr data 13 => 40 201 => 20 300 => 30 1012 => 50 addr will be your read address excluding any address that reads zero data. So you need some logic to select out relevant addresses. data will be any data read as nonzero. - Altera_Forum
