12 years agosorter in vhdl
hi every one i want avhdl code to sort integer input ascending if i have an array such as 1,8,9,7,2 the out put will be such as 1,2,7,8,9 i search a lot but didn't find any code that he...
12 years ago --- Quote Start --- we are not exchanging ram entries but want to sort som data in ascending order to output. --- Quote End --- I think you can either sort the entries in RAM (e.g. using the well-known bubble sort algorithm), or build up an index table and output a sorted stream using this index. I don't see a third method. But anyway, let's look for the results.
