12 years agosorter in vhdl
hi every one i want avhdl code to sort integer input ascending if i have an array such as 1,8,9,7,2 the out put will be such as 1,2,7,8,9 i search a lot but didn't find any code that he...
12 years ago --- Quote Start --- no , i will get a large number of data but, if you may remember i want the sorted trigraphs (codes) to compute the distances between two trigraphs ,do you remember?? so,i want it to be in a single output (independent) not including in the ram content i hope you understand me --- Quote End --- do you mean like this:(then you need to discard any zero outputs)
library ieee;
use ieee.std_logic_1164.all;
use IEEE.numeric_std.all;
entity bubblesort is
port(
clk : in std_logic;
we : in std_logic := '1';
trigraph : in std_logic_vector(7 downto 0) := x"0F";
duration : in integer range 0 to 1023 := 5;
read : in std_logic := '0';
dout : out std_logic_vector(7 downto 0)
end entity;
architecture rtl of bubblesort is
signal address, rd_addr : integer range 0 to 1023 := 0;
type mem is array(0 to 1023) of std_logic_vector(7 downto 0);
signal ram : mem := ((others=> (others=>'0')));
begin
--infer ram
process(clk)
begin
if(rising_edge(clk)) then
dout <= ram(address);
if(we = '1') then
ram(address) <= trigraph;
end if;
end if;
end process;
process(clk)
begin
if rising_edge(clk) then
if read = '1' then
if rd_addr < 1023 then
rd_addr <= rd_addr + 1;
end if;
end if;
if read = '0' then
address <= duration;
else
address <= rd_addr;
end if;
end if;
end process;
end rtl ;
