12 years agosorter in vhdl
hi every one i want avhdl code to sort integer input ascending if i have an array such as 1,8,9,7,2 the out put will be such as 1,2,7,8,9 i search a lot but didn't find any code that he...
12 years ago --- Quote Start --- I think you can either sort the entries in RAM (e.g. using the well-known bubble sort algorithm), or build up an index table and output a sorted stream using this index. I don't see a third method. But anyway, let's look for the results. --- Quote End --- The post is about two streams of data (duration and code). if I have one stream e.g. : 2,6,1,0,7,9,14,1,3,1,6 ...etc I can sort it using one ram of say depth 16, 3 bit width. each data arrives as address, I run counter on the 3 bits data(read 0, increment, write back into ram) thus I get in the ram at the end of data set: location:data 0: 1 1:3 2:1 3:1 4:0 5:0 6:2 7:1 8:0 9:1 10:0 11:0 12:0 13:0 14:1 15:0 hence when I read ram back in ascending address order I get: 0,1,1,1,2,3,6,6,7,9,14 I think it is sorted now
