15 years ago
Sopc Help
hi again,
I'm using a SDRAM controller in SOPC. but things are not working right.
Failing paths, buffer of templates are getting full , ...
I'm using master write and master read MM-templates from the site.
I connected 3 read's and 5 writes to the SDRAM Controller. What else do i need to do?
Can anyone plz help me with a good tutorial or a easy reference design ?
Edit: For any help i added a pic of the sopc
    --- Quote Start ---
    do i need a diffrent ip.sdc for the sopc? Here is my SDC-File for main design:
    --- Quote End ---
    Sopc builder should have generated automatically a .sdc file for your system.
    You must include it in your Quartus project.
    Also make sure your checked the "Timing driven synthesis" in Analysis&Synthesis settings and follow the other guidelines reported by timing optimization advisor.
    If all this fails maybe the 144MHz frequency is really too high for your device.
    Final note: probably this is not your current problem, but usually you must drive the sdram clock pin with a phase lead relative to clock used by sopc system.
    --- Quote Start ---
    --- Quote End ---
    You have to enable the settings for that? Cauze i can't find it in the main
    directory.
    --- Quote Start ---
    --- Quote End ---
    I did.
    --- Quote Start ---
    --- Quote End ---
    Probably you need to apply that in the sdc aswell. How?
    --- Quote Start ---
    You have to enable the settings for that? Cauze i can't find it in the main directory.
    --- Quote End ---
    AFAIK sopc builder generates the sdc file by default, together with the .qip file which contains the hdl file references. At least this is true for the Quartus version 9.0sp2 I use.
    Did you select TimeQuest as time analyzer?
    Regarding the sdram clock phase, I remember it must be calculated somehow like this (although I'm not completely sure):
    - pre-compile the project with 0 phase shift
    - search the PLL offset in the timing analysis report
    - search the sdram clock combinatorial delay from pll output to clock pin
    - the sdram clock phase lead must be set that the sum of pll offset and combinatorial delay is a bit longer than the sdram setup time
    - recompile the Quartus project
    I use the same SDRAM as yours and EP3C40: with Fclk=100MHz I set dram clk phase = -27degrees = -0.75ns. As a rule of thumb you can also try -0.75ns which for your 148MHz would mean a phase lead of 40deg.
    --- Quote Start ---
    --- Quote End ---
    I only see the SDC wich i made. I don't have one generated by SOPC builder. I use version 8.0.
    I'll try shifting the SDRAM CLK but I probably need to reduce the speed of
    the avalon bus with all those components on it. I was running it at 144MHz.
