15 years agoSopc Help
hi again, I'm using a SDRAM controller in SOPC. but things are not working right. Failing paths, buffer of templates are getting full , ... I'm using master write and master read ...
15 years ago --- Quote Start --- AFAIK sopc builder generates the sdc file by default, together with the .qip file which contains the hdl file references. At least this is true for the Quartus version 9.0sp2 I use. Did you select TimeQuest as time analyzer? --- Quote End --- I only see the SDC wich i made. I don't have one generated by SOPC builder. I use version 8.0. I'll try shifting the SDRAM CLK but I probably need to reduce the speed of the avalon bus with all those components on it. I was running it at 144MHz.
